I have just purchased a used BeoLink Wireless . It is to be the second reciever in my setup.
I tried connecting it as the second reciever but it would not connect. I disconnected my original reciever and tried to connect the new one again on its own- no luck. Did a factory reset on my transmitter and the new reciever and tried to connect - no luck. Tried changing my reciver to a transmitter - no luck. Changed the new one to transmit and tried to connect either of my old ones as recievers - nothing. Set my old ones to transmit & recieve and they connected almost immedeately. So they both work!
The box of my new Wireless has "updated to 2.10e" hand written by the lable and I'm assuming the that means the software has been updated so have written to the seller to confirm that the one in the box he sent me has that software version.
Looking at this thread it would seem I may struggle to get them all working together as mine have the original software from when I bought them about 4 to 5 years ago.
1. Does anyone know the cost of updating the sowtware here in the UK.
2. What benefits does the newer software bring?
3. Can the software be downgraded?
If the software update brings no significant change, I may just downgrade the one, but if it is beneficial I may have to upgrade my two. Cost will have a bearing!
Thank you
Stoobie
