Hi all,
Is it possible to have two separate music systems connected to a BV7 via ML to play music through the TV's speaker setup?
Current there is a BS9000 connected to the BV7 via ML and this works fine.
Now if I add a second one, e.g. a BS5500 stack with the Beolink SW etc, can I set that up to work as well?
So two parts to the question.
1. Is it possible to connect the BS5500 with the correct adaptor, a 1611 perhaps?
2. If only one of the music systems will ever be powered on at any time will it work if I use the small ML (5 or 6 port?) connecter box to connect both through to the TV?
Sorry for what seems a simple question!
Cheers
