Dear B&O professionals :)
I've some issues in my NL/ML network. I'm going to try to explain as much as I can and hopefully I'll get some helpful inputs back.
Installation:
- BeoVision Avant 55, connected via NL to the router/switch
- BeoLink Gateway, connected via NL to the router/switch
- NL/ML Converter (without speakers!), connected via NL to the router/switch and via ML to a BeoLab 3500
- BeoLab 3500, connected via ML to the NL/ML Converter
- MasterLink Power Box between BL3500 and NL/ML Converter (this box is a new B&O product to deliver power to the ML to get rid of an "real" audio master
Problem:
First of all, I installed all the devices to have a alarm clock in de morning in both rooms. I know, it's an expensive installation (BLGW and NL/ML Converter) just to have an alarm clock, but that's unfortunately the only way to programm weekly alarm clocks like in an old ML setup...
I can currently use my BL3500 with the sources of the BV Avant and it works fine so far but I'm not able to program an alarm clock for the devices. There's is not BL3500 visible in the BLGW, and I don't know why.
Questions:
- If I progam an alarm clock, I can now tell the BLGW to switch on Netradio on the Avant and the NL/ML Converter to use the source of the avant. I actually thought the BL 3500 will turn on automatically (timer is on) because the Converter sends a trigger (as the old ML audio master did). But the BL3500 doesn't turn on. Why?
- Do I have to connect the BL3500 directly to the BLGW as well? (Let's say install a junction box next to the BL3500, then connect the ML side of the BLGW to the juction box additionally to the BL 3500 --> NL/ML Conv. connection? Is that the way to see the BL 3500 in the BLGW resources?
- If I eventually can see the BL 3500 in the resources of the Gateway, do I have to set the alarm just for Avant and BL 3500 or does the NL/ML Converter has to turn on, too?
I know, it's a bit difficult to explain, but I tried to give my best. Attached you can find a picture of the installation... and there's currently no connection between BLGW ML side to the BL3500...
Best regards and thanks for any help!
Rémy
