Beolink coverter Networklink Masterlink
hi all,
I recently purchased a Beolink Converter, Networklink
masterlink.
I wanted to knstall today. Opened the box and no manual in.
does anyone has an manual. This thing seems to be quiet powerful with a lot of connections.
or do I just connect my Beosound 9000 and my beovplay V1 with it and it all works automatically???
thanks,
stefan
Hi Stefan
It wouldn’t work right off the box like the other converters... you can find all there is to know in the Beolink handbook:
Hi Soren, thanks for the nice pdf.
But I have one more very important question.
In the pdf they write
"the BeoLink Converter NL/ML has a build-in Web Interface, which is used for set-up"
How can I "enter" this Web interface???
What is the address? How do I need to connect the converter?
I have not yet connected it to anything.
So it might work seamless as soon as I connect to my V1, but I just don#t know.
Any help is appreciated.
Thanks,
Stefan
First of all, i’ve spent many week or months in trying to configure the ML/NL converter. It’s a powerful although hugely complicated beast. The manual wasn’t overly helpful, but there were a few folks in this forum who really greatly helped. You may want to search for the main thread, which has a few pages on various configurations.
To answer your Q: you need to connect the ML/NL with your home network. It doesn’t have wifi, so you need to connect your lan with a network cable to the ML/NL. Also power of course. That’s the first step. You can see the IP in your router and then connect through it in your web interface. you could also use the beosetup up, but i found the web interface more convenient.
If you want to connect speakers to the ML/NL, use the PL. If you want to connect other ML devices to it, use the ML out.
@Steve
You asked questions in the B&O app thread about using a Moment in an integrated setup. I thought it might be more appropriate to respond in this thread where it could be more useful to others, too.
I connected an NL/ML converter via ML to my BeoVision 10. By doing so, the BeoVision 10 can appear via NL as an available BeoVision for my Moment to integrate with it to use that BeoVision's speakers. This selection is done on the Moment when you take off the back panel to get into the settings. Then you make the selection to use a BeoVision's speakers under the "sound" and then "speaker setup" menu.
For the O.P.: It's true that the regular manual for the converter is not very detailed. There is a MUCH more detailed manual available. If you PM me, I'd be happy to send it to you.
@Steve
I forgot to add that I have my Moment connected to NL via CAT 7 -- as I have all of my NL devices connected by cable rather than wifi.
I have my NL/ML Converter set as A.Master with my BeoVision 10 set as V.Master. I use the NL/ML converter's web interface to map the Moment (and other NL devices' sources) as available on ML as CD, A.Mem, etc.
BTW, I'm getting ready to add my FIFTH NL/ML converter! I'll then have the following legacy ML devices available on NL:
BeoSound 9000
BeoSound 5
BeoCenter 2
BeoMaster 5500 with BeoGram 9500 and BeoGram 3000 turntables
BeoSound 2300
see for the IP address in your router, then open a browser on a Mac/PC/or.. and add the IP address.
The web interface should start. Standard user/password: admin/admin
Or install the Bang & Olufsen app. Be sure the BLC is connected to the router and is running. Add the BLC as source in the app; choose the BLC; select "product settings" and " about"  - the IP address is shown. etc....
Note: I refer to the Beolink Converter NL/ML as BLC.
Be aware that you can’t use the Bang & Olufsen app any more... they removed that functionality some updates ago.
Instead you have to use the “old” BeoSetup app.
Søren
Søren
So true, but still a relative easy way to learn the IP address of the BLC.
I prefer a web browser to change settings on a BLC..... still the easiest.
Dear all,
thank you all for the advices. I will try to figure out set the system up.
Thanks.
Stefan
