Beolink convertor help
Hi allI have had a 9300 connected to my system for about two years via a beolink convertor.This week I removed the 9300 and convertor as I was having some plastering done.Now it's all reconnected the 9300 is not powering up from anywhere on the ML.It works locally only reset the options on the main room tv and the 9300 but nothing.I switched everything off one by one and this has not helped.Any ideasThans
Also everything is connected as it was before.Driving me mad that they did not put any form of indicator on this device
Just an idea, a 7pin DIN of the AV cable also fits into the 8pin PowerLink socket of the BeoLink Converter ...
Hi thereProblem solved, well it will be when I can be bothered to get under the floor.Seems with all of the movement the green cable is not connected anymore.I got out the trusty old multi meter and buzzed out each cable.Turns out green is data and that is currently missing in action.
