Beolink Converter NL/ML or new NL products
Ralf wrote:
For the Beosound 2300 you will have to add an extra Beolink converter, because you can't have two audiomasters on your ML.
Hi Ralf!
So you confirm multiple nl/ml converters can sit on the same home LAN without doing any special VLANS!?
Please reply. Thank you.
i'm not ralf, but i can confirm
Thanks Steve!
This means I will have 3 nl/ml converters on 3 different Masterlinks.
N.Music & N.Radio can come from BS/BM5 on ML1.
Then I can use the BS2 for ML2.
And finally the BS Moment or Essence which I plan on buying.
That makes room for one more Masterlink! lol
Hi everyone.
Thanks for your posts, I have come to the conclusion that NL/ML converter is not the way for me to go. I will instead go for pure NL products in the future. As someone said earlier, NL/ML converter works, but its not as user-friendly in a day to day basis. For my bartroom I will buy a A6 or wait a little for a new cheaper NL product.
Brgds Mogens
I think the M5 is the cheapest NL products at the moment and maybe for the foreseeable future
