Hello BeoWorld members,
I connected an other pair of BeoLab boxes to my BeoLink Active and now I would like to know how I can adjust the sound settings (treble and bass) into a neutral position?
Any Ideas?
Thank you for you feedback
Klaus
Any Ideas?
Klaus
On the B and O web page, if you go to the menu for manuals, it is possible to select the Beolink Active manual and it explains how to adjust the teble and bass. Hope this helps.
Of course I read the service manual. At the BeoLink Active I changed my BeoLab 6000 into BeoLab 1 and BeoLab 2 boxes. Now I would like to adjust the BeoLink Active back into a neutral position (factory setting). The problem is that there is no indication at the BeoLink Active available.
Klaus
Maybe RESET - GO ?? As described in the user manual...
Stefan
Or you could do it even without a manual. If I recall correctly there are only 7 levels for either ‘direction’ (+/-) when you adjust a setting (balance, treble etc.): so you can pick a setting and press an arrow at least 14 times (=up to) and then 7 times the ‘opposite’ arrow which would give you exactly the desired neutral value ( good there are not 50 possible levels!) … I’m also sure your ears will play a helpful role while you will be doing that. A bit old-fashioned I admit, but it might solve the problem.
