Beolink 7000 rds version 1631 sw 3,0
Andreasi995 wrote:
I am living in the city of Trondheim/Norway.
Ok, that's useful info, perhaps someone on the forum knows where you could go. As Leslie says, if you have no experience with this sort of stuff you should leave it to someone who does.
/  Johan
Thank you very much Leslie.
You are very helpful.
I cant thank you enough.
I am no searching for a guy here in Norway to do the job.
I hope i can find someone.
I have myself replaced the old battery for a new one.
Do you know if there is other batterys inside the beolink which have to be replaced?
Thanks Johan.
I sm no searching for someone in Norway to do the job.
Do you know someone in Sweden to work it out?
Shall I have a look at it?
Thank you for your offer.
I will first try to contact some bang olufsen dealer here in Norway.May be they can repair the item.
I spoke to a bang olufsen seller in Oslo and he told me that i probably have to replace 4 or more caps(as you told me in beoforum)
He reommended too ,to replace a litium battery inside the beolink and at the same time set in a new blue display.
If they cant help me i hope i can come back to your offer?
Is i possible for you to replace caps,litium battery and the blue display???
Best regards
Per-Arne
Sorry, never replaced the backlight thing but as you might know there is an excellent thread how to do that. I have ordered the materials but still need to do this job!
Hello again.
I have no discovered that my beolink 7000 is not av version 1631 but 1540.
I bought the item on the ebay and the seller announced it as av version 1631 .
I saw the description underneath the beolink when elevated.
I paid euro 365.
1)What is the main
difference between version 1540 and 1631.?
Is that the reason of ,no contact in the display facing my beomaster 7000.?
I have no user manual for the version 1540.There are some differences on the red display button
.Control has replaced the clock button.
2)Will rds work out?
3)Are the caps which have to be replaced different?
So long
Per-Arne
