Beolink 7000 rds version 1631 sw 3,0
Hello.
I have a well function beosystem 7000.
Ihave set it up with my old beolink 7000 and the two way communication function normal.
I have bought another beolink 7000.
I tried to connect the "new beolink"7000 facing my beomaster 7000.
In the display ,no contact come up.I tried to remove my old beolink to another room and then tried again without luck.
I removed then all the audiosources-then store-then reinstalled thhe audiosources -then store but still no contact is remaining in the display.
The "new beolink 7000"does not function as a two way comunicator,just as a one way communicator.
Is there anybody out there which can help me solving this trouble.
Search the (archived) Forum... Issue has been covered several times.
Best regards
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thanks Ralf.
I will looking for the answer
But if you can explain the solution of my problem i will welcome it.
The Viking
I don't know but it is on this website...
Probably 4 caps that needs to be replaced!
Check
Thanks Leslie
You are showing me 4 caps but  the picture shows 2 new installed caps.?
Where can i buy such caps?
And do i need to install them?
The Viking
I mean what do i need to install them?
The Viking
If you don't know, you should probably let someone else do it. Where do you live?
/  Johan
I am living in the city of Trondheim/Norway.
Best regards
The Viking
You do need skills to do the job especially for the SMD caps under the tin can.
If you're not experienced enough let someone else do the job!
I put comments on each slide, 4 caps...
