I removed "tv" from selected sources, and the "no contact" message appeared after my previous attempts to set the clock and timer - the message "programmed" and then "no contact" appeared.
Beolink 7000 problem
Definitely sounds like those capacitors need to be replaced.I removed "tv" from selected sources, and the "no contact" message appeared after my previous attempts to set the clock and timer - the message "programmed" and then "no contact" appeared.
So sorry, Mariusz, I’m not near my BL7000. I’ll check again when I’m back home to see if you have found the answer, and if not I’ll try to find the path on mine. But I have to say, bad capacitors are very good candidates for what you’re experiencing. 🙁LawrenceThank you, Lawrence, for a very quick response, I can not, unfortunately, locate the 2-way position in the system / audio option. On my beolink I go into the panel - setup - display system - compnts - audio, but I do not see the 2 - way position. Mariusz
