Hi gert
nickel metal hybride batteries, they are NimH. Some people use these with good results. I have several BL7000 and I used Nimh as well and after 3 moths or so they stopped charging. On the others I use Nicad (these types were originally used by B&O) and these work best for me. Pay attention by wiring those 5 batteries; if you short circuit them they generate heat.
I have one BL7000 still in pieces; was changing the backlight foil but I do not manage to put it back together. The rubber strips for the contact with the lcd slips away every time when placing it into the black plastic housing and then on the pcb. The result is that not all lines are presented the way it should. It is a pity because the difrence is like night and day the backlight is like new and not as decade when they are older.
Verry frustrating. If I found a good way, then the life of the BL7000 could be extend for a long period of time. Most of the other problems like "no contact" recap changing the backup battery etc etc and are resolved here by many members here on BW.
