Beolink 5000 opperation
Can anyone explain if its possible to opperate a beocenter 9000 with a beolink 5000 i have so far only managed to turn the beocenter OFF with it 😂its just the two items no link or any thing! and can it get the CD to repeat play?
sorry if this sounds a dumb blond type of question ...
Maurice
Hi!
You have to make Bl 5000  One Way for Audio. Download user manual from www.bang-olufsen.com if you don´t know how to do it
Hi, to set the Beolink 5000 to 1-way communication:
* press and hold Stand-By untill the display shows: STD. BY SYSTEM
* press SHIFT , MENU
display shows: TRMINAL SETUP?
* press PLAY
display shows: VIDEO TWO WAY
* press arrow up/down
* PLAY
* arrow up/down
* PLAY
display shows: TRMINAL ACCEPT
Beolink 5000 will return to stand-by
and is now set to 1-way
