Beolink 1000 versions
We cut test this! If somebody has a LC2 and a BL1000 mrk3+, then press shift + link and see if it controls the light?
I think the shift command maybe only, is setting a bit in the bit stream it's sends!
F.ex
A.tape                00101010
shift + A.tape      10101010
and
A.tape                00101010
link + A.tape       01101010
would be nice to know 🙂
Shift changes the key code (last 2 digits), link sets a bit...
11:00191  A.TAPE
11:00194  A.TAPE2 (SHIFT + A.TAPE)
11:10191  LINK + A.TAPE
11:10194  L-A.TP2 (Beo4)
11:00091  AV + A.TAPE (Beo4)
number_of_bits:data (both in hexadecimal)
I've just acquired a Beosystem 7000 that came with a beolink 1000.
Most of the controls are quite simple to do except for controlling the radio functions.
I can't seem to search for new station and I can't display RDS or clock, all I can do is use the stations that were previously programmed.
Does someone know what the commands are to do this, or do I need a Beolink 7000?
Andrew
Hi Rabble.
The Beomaster does not display RDS or the clock, sorry.
RDS and the clock are displayed on Beolink 7000.
As for radio tuning, it's easy with Beolink 1000
Radio   goto    up or down button.
Once you get the channel you want
Store   7    store (Choose your own number)
Come back if you have any problems.
Andy T.
It's still possible to get a brand new BL5000 and BL1000  🙂
Hi Andy,
thanks for the info. it seems to work, however I can't seem to display the frequency of the channel.
Is this something also only avail. on the Beolink 7000.
I thought that the main difference between the 6500 and the 7000 was that the RDS would display on the receiver.
If that's not possible then what's the difference?
Cheers
Andrew
No, you can't see the frequency on the Beomaster, only on the Beolink7000.
However, if you know the frequency you're after, you can enter it in four figures on FM only.
Radio    Goto    1015    store    7    store   =  101.5 FM stored on channel 7
As soon as you press Goto, it should say "F" on your Beomaster.
If you want change to AM, then
Radio    Goto    Shift    Sound    then immediately up or down button before it slips back to FM
It should say "A" on the Beomaster..
I am not 100% sure but I think the only two differences between 6500 and 7000 is that
6500 only available in White or Aluminium 7000 also available in Black and mirror finnish
7000 has RDS decoder whereas 6500 hasn't.
RDS decoder is not much use unless you have a Beolink 7000. However, if I remember correctly, Channel name and frequency can be seen on a linked in TV like LX4500.    Radio    AV    Radio    Menu   springs to mind but don't quote me on that!
Andy T.
The RDS module can also be fitted to either later BeoMaster 6500s, or all 6500s...
Hi Andy,
thanks for all your help, at least now I can listen to radio and not just static.
I guess I'll be searching for a Beolink soon, as the only reason I chose the 7000 over the 6500 was for the RDS.
Regards
 Andrew
Does anyone know if you can switch loudness in/out with a mk3 control? I can achieve this with my mk2 using a shift command but not on my mk3...
*I should add this is with my master 5500...
