Hi everybody,
while fixing my 9500 an additional Beolink 1000 resurfaced which I hadn't used in a while. So I thought to give it a try and found it nearly blasted my ears away turning the volume all up on the 9500.
I assumed some mechanical problem (dust and debris stuck under the rubber buttons) so I disassembled the remote, cleaned all up and checked the batteries. I also tried the trick with shortening the contacts to purge all electrical parts.
But nothing changed.
Checking the infrared with a camera shows that the remote is sending commands all the time. This is also the case when pulling out the batteries and putting them back in WITHOUT hitting any button. When I push a button (any), I can see some interruption in signal sending, so I guess there is still some kind of interaction between buttons and IR sender.
Is there a solution to this problem?
Yours
Ray
