Beolink 1000 - Questions ????
Can anyone tell me where or how to get to the menu key on my Beolink1000?
Not sure what model it is but I'm trying to "tune" in stations to my Avant using the 1000
The remote doesn't have a "menu" key.................
Can I tune in the Avant with this remote, if so how ?
Alternatively, can I manually tune the Avant, if so how?
Cheers,
Steve
You must have a Mk1 or 2 Beolink 1000
So MENU = SHIFT, TEXT
GO = PLAY
Thanks for that ............. I really appreciate it !! - Top Man
Here are some more key combinations which may be of use to you
Beo 4    Beolink1000 MkI & II    Beolink 1000 MkIII & IV
[red]        [SHIFT] [<]                   [SHIFT] [\/]
[blue]       [SHIFT] [>]                  [SHIFT] [/\]
[green]     [SHIFT] [<<]                [SHIFT] [<<]
[yellow]    [SHIFT] [>>]                [SHIFT] [>>]
[MENU]    [SHIFT] [TEXT]              [MENU]
[LIGHT]    [SHIFT] [LINK]              [LIGHT]
[GO]        [PLAY]                          [PLAY]
[DTV]      [SATELLITE]                  [SAT]
[DVD]      [SHIFT] [CD]                [SHIFT] [SAT]
[PC]         [SHIFT] [STORE]           [SHIFT] [STORE]
[DVD2]    [SHIFT] [V.TAPE]           [SHIFT] [V.TAPE]
[V.AUX]    [SHIFT] [TV]                 [SHIFT] [TV]
[A.AUX]    [SHIFT] [RADIO]           [SHIFT] [RADIO]
"N.RADIO"    [PHONO]                   [PHONO]
"N.MUSIC"    [SHIFT] [A.TAPE]       [SHIFT] [A.TAPE]
 Chris
How about other way around, using Beo4 as Beolink1000 with, for example, MX5500?
I guess, need to find at least sound, picture, store etc.
Pekka
Do you have same info for Beolink 5000 and Beolink 7000 ?
