Beolab2
Hi I have just purchased a beolab2 sub the fuse has blown in the plug it arrived with a 3 amp fuse insitu is this correct or should it be 5 amp
regards
The correct value is printed on the mainboard next to the fuse. It depends on which voltage the BL2 is driven.
It will be 4A when used with 230V and 8A when 110V is available.
