Beolab10 vs beolab7.2-7.4
Hi all. I'm moving home soon and will be doing some work on the new place so I am going to install an electric projector screen well the work is being done. I am planning on using a beovision 7-40 as the everyday tv wall mounted with beolab 8000s as fronts wall mounted. I will probably use beolab 6000s as rears unless anyone has any other suggestions? Maybe 4000s or another set of 8000s? It's the centre speaker  I cannot decide about I like the look of the beolab10 although this is a mono speaker am I correct? Then there's the 7.2 or the 7.4? Which would people recommend regardless of looks?? I have searched for people's views and can't find a single thread about them? We're they a flop? Any help, views, opinions appreciated
thanks in advance
david
I, too, plan on a B&O surround sound system.  I, too, am unsure what substantial difference there is between the BL 7-4 and 10.  I see that the BL 10 has a slightly deeper bass response vs. the 7-4.  I take it that this is because the former has a greater cabinet volume.
As a general rule, I think it's best not to have drivers aligned horizontally due to differing distances from the drivers to the listener.
David
Hi thanks for the replies. I am now waiting for the press release for this new surround sound before making any decisions. Now I am going to start looking into projectors and electric screens. I know projectors have come a long way and are unbelievably clear these days. Does anybody have any rocomendations? Would b and o recommend a certain one? Also screens is there good ones and also ones to avoid? Chances are I will also be needing a lift for the projector so that it pops out of the ceiling when in use and back in when not. Again does anybody have any recommendations along with any to avoid? Thank you all in advance . Cheers
epson and jvc do some cracking projectors, b&o usually say sim2 for projectors,
