BeoLab Transmitter: I'm Confused
Hi.
Sometimes it doesn't take much to confuse, but hoping you could help.
With the BLT1, does this essentially mean:
> I can plug my TV in to the white box via the Optical audio
> Plug a receiver in to each of my BL3s
> And essentially use my BL3s with my TV (Sony)
OR
Does it still require some sort of receiver?
That's why I'm confused, because if i did a receiver, I could still essentially use a PL to RCA cable in a receiver.
I don't have a receiver and was hoping to avoid that route.
Please help
Theres no volume control in the BLT1.
That means all the inputs on BLT1, has be volume regulated by something else then the BLT1.
The BLT 1 has:
-PowerLink Inputs.
-Optical input.
-Stereo RCA line input.
If the Sony tv has a volume regulated optical output you could use that, but since it probably doesn't (I have never seen a Sony TV with that spec.).
You need to have a stereo (preout/Headphone) analog output. that can be connected to the BLT 1's Stereo RCA line input..
Copy/paste from sony user guide (model X900):
Connect with an audio cable or headphones. You can listen to TV sound through
your stereo system or headphones.
To set the sound output for headphones or an external audio system, press the
HOME button, then select [Settings] → [Sound] → [Headphone/Audio Out].
When you set [Audio Out] in [Headphone/Audio Out], select [Fixed] or
[Variable], press the HOME button, then select [Settings] → [Sound] →
[Audio Out].
Bang & Olufsen have created this fantastic guide for the BLT 1: http://www.bang-olufsen.com/interactive-guide/
The answer: Yes you can connect BLT 1 with a 3rd party TV if it has a headphone output (volume regulated stereo output), without a receiver, preamp or surround sound processor.
But if you have an idea about surround sound with the BLT1, I would suggest you buy a BeoSystem 4 (4600USD) or a 3rd party surround sound processor (price 1000USD).
Sale your TV and buy a BeoVision 11 or the new Avant. The transmitter 1 is included in the TV.
Thank you Beo Cet.  That's great
And BeoBoy!  lol.  I was waiting for someone to say that to me :-) GSOH there.
BEOCET wrote:
Important new update to the Transmitter 1, makes it possible to connect a Samsung, LG or Sony TV to the BeoLab Transmitter 1 while still using the TV’s own remote to control the volume level.
The TV can be connected to the BeoLab Transmitter 1 via TOSLINK or fixed line-out . You can buy an external IR-receiver (model name RCV-3000) that needs to be connected to the Transmitter 1, buy it from a local B&O dealer.
That's great news
The TV can be connected to the BeoLab Transmitter 1 via TOSLINK or fixed line-out.
That sounds great. Would limit me to stereo though, right? Sony, Samsung et al would not have a dolby receiver and I assume the transmitter would not play this role?
Hi Beocet,
Now you have me confused. I have tried to connect my Samsung TV to the Transmetter 1 and using the TV remote to control the volukme
 - no luck. I was told that Samsung's external speakers are " non variable".
I ended up buying a pre - amp and running all the connections through the pre amp and then on to the transmitter.
Please clarify
RCV3000 makes it possible to connect a Samsung, LG or Sony TV to the BeoLab Transmitter 1 while still using the TV’s own remote to control the volume level.
Features:
RCV3000 is connected directly to the BeoLab Transmitter 1 via the included USB cable
RCV3000 captures IR signals from the latest generation of Samsung, LG and Sony remote controls
RCV3000 passes volume up / volume down / mute / unmute commands on to BeoLab Transmitter 1
Please see a list of remote controls tested with RCV3000 on BeoLab Transmitter 1 below.
For your reference and inspiration, we have during the development tested the functionality on the following TVs and their remote controls. Please note we have no plans to extend compatibility with other brands than LG, Sony and Samsung for now.
TV brand
Model
Release year
LG
42LD550N
2010
47LK550
2011
55LW980W
2011
50PM680T
2012
42LS560T
2012
50PH660V
2013
47LM860W
2012
55LA970W
2013
Sony
KDL-40CX521
2012
KDL-40E5520
2010
KDL-40EX726
2010
KDL-52WX805
2013
KDL-42W805A
2013
KDL-65HX955
2012
KD-5X9005A
2013
Samsung
UE40f6345
2013
PS51f5505
2013
UE50F5000
2012
UE32F4005
2012
UE40F6170
2013
Is the RCV3000 only working for LG, Sony ans Samsung? What happens with Loewe, Metz? Exists a list of supported TV?
And a last question: Wgats the price?
And that would still be stereo only?
