Hi Steve!
and there's one man reading our forum that could answer the question: Our beloved Geoff Martin :)
Beloved? My word...
Using a loudspeaker for sound reinforcement has some different implications than when they're used for playing music in the home - or in the studio for that matter.
Regarding the "studio monitor" question: All current Bang & Olufsen loudspeakers have a "sound design" that is intended to produce the same overall timbre at the listening position in an average domestic living room as you would get from a studio monitor in a studio. This does not mean that they are modelled after studio monitors - nor do they behave like studio monitors (in terms of on-axis frequency response).
It seems to me that you have to worry about two things with respect to sound:
- can the speaker produce enough sound pressure level for the musician and the venue (and therefore the background noise)
- is its internal latency low enough to be used for live sound.
For example: BeoLab 90 can produce plenty of SPL - but in its lowest latency mode, it has a throughput delay of 25 ms, so it is unusable for live sound.
BeoLab 4 has 0 ms latency, but it might not be able to produce adequate output level...
This is all I'll say about the subject - I'm just chiming in with what I think are the two important things to consider.
Cheers
-g
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
