Beolab penta mk3
They look like foam to me - I have the rubber ones, and they are darker and smoother (I've compared with a identical foam surround which was sent to me as a sample).
I've not had any problems with fitting the rubber surrounds on mine, and the inner edges bend down on the cone just fine once you get some glue on them. I agree with the point about the outer edges (That it wouldn't hurt, if they were a bit bigger), but the surrounds can be used, if you take your time to get the surrounds placed correctly on the cone so they have the same amount of space on each site of the outer edge and out to the basket.
- Dennis
Same experience Dennis, that's why if Beobuddy find them useless I surely can use them!
Re: Foam/Rubber, I did both types.
Foam from speaker friends.
Rubber from Good Hifi.
They will both work. I don´t think the rubber will get loose by time due to vibrations. As said earlier the foam where easier to work with, but also the foam rings could have been larger in the outer diameter. From a sound quality perspective the foam-ring would in theory sound better, since the less weight, and since that't what the whee originally equipped with. However I must say that it is absolutely impossible to hear any difference. In theory the rubber ring will last longer, but you never know until afterwards.
Regarding receiver: If you run active speakers i doesn't matter so much which receiver you use since the power amplifier is not used. Personally I'd say the BC 9500 is better built than the 2300 and much more good locking than the newer systems. I also offers two way communication.
Okay, more experiences from other users! Bo, what's the other suplliers name, "speaker or audiofriends"?
Sorry, Audiofriends it is.
Did you do recapping of Penta 3's? If yes could you please give me more details where you bought them?
Just checked the values:
3x 68uF/100V
1x 22uF/100V
2x 8,2uF/100V
1x 27uF/100V
I recapped, two pair of Pentas. The crossovers are slightly different from speakers with serial 04771089.
Part list for speakers prior to 04771089:
Filter Nr uF V %
Woofer & Tweeter C6: 0,68 35 10%
Midrange C6: 0,68 35 10%
Midrange C7: 0,68 35 10%
Woofer & Tweeter C4: 2,2 100 10%
Midrange C4: 3,3 100 10%
Woofer & Tweeter C5: 3,9 100 10%
Midrange C2: 8,2 35 10%
Midrange C5: 10 35 10%
Midrange C1: 22 35 10%
Midrange C8: 22 35 10%
Woofer & Tweeter C3: 47 35 10%
Woofer & Tweeter C1: 68 35 10%
Midrange C3: 82 35 15%
Woofer & Tweeter C2: 220 35 20%
Part list for speakers from 04771089 and forward.
Filter Nr uF V %
Woofer & Tweeter C9 0,68 35 10%
Woofer & Tweeter C10 0,68 35 10%
Woofer & Tweeter C8: 1 100 10%
Midrange C4: 3,9 100 10%
Woofer & Tweeter C7: 5,6 35 10%
Midrange C5: 8,2 35 10%
Midrange C1: 27 35 10%
Woofer & Tweeter C3: 68 35 10%
Midrange C3: 68 35 15%
I bought caps from link.
Pos   Qty     Articleno           Article description                     Price           Sum
1     6       1341225             MKTA/3.9/160                            1,30 Euro       7,80 Euro
2     2       1341233             MKTA/5.6/160                            1,70 Euro       3,40 Euro
3     6       1341240             MKTA/8.2/160                            2,50 Euro       15,00 Euro
4     4       1341210             MKTA/2.2/160                            0,80 Euro       3,20 Euro
5     2       1341200             MKTA/1.0/160                            0,50 Euro       1,00 Euro
6     6       1341106             ERA/22/100/1                            1,10 Euro       6,60 Euro
7     2       1341108             ERA/33/100/1                            1,30 Euro       2,60 Euro
8     8       1341110             ERA/68/100/1                            2,00 Euro       16,00 Euro
9     2       1341220             MKTA/3.3/160                            1,10 Euro       2,20 Euro
10    2       1341030             ERA/10/100                              0,80 Euro       1,60 Euro
11    2       1341105             ERA/47/100/1                            1,60 Euro       3,20 Euro
12    2       1341112             ERA/82/100/1                            2,20 Euro       4,40 Euro
13    2       1341090             ERA/220/63/1                            2,40 Euro       4,80 Euro
Delivery costs................: 15,00 Euro
Sum excl. Vat.................: 72,87 Euro Vat (19%) ....................: 13,93 Euro Sum incl. Vat.................: 86,80 Euro
Note the burned coil. Some of the coils on the crossover from No. 04771089 are underdimensioned (too thin wire). They will run too hot when listening to high volume for longer time. The older crossovers are more robust.
Thank you very much Bo! You're a great help🤒Beer
Hello again.
1)I have mailed bang olufsen i Norway about new midrange drivers for beolab penta.
They don't produce them any more.
I have search for new midrange drivers on ebay.
I found old refoamed midrange drivers.
My question is:Is there a thecnical difference between midrange drivers in beolab penta mk 1, mk 2 or mk 3?
Is it for exampel possible to use midrange drivers from beolab mk 1 to mk 2 or mk 3 or visa versa?
2)Is it difficult to open the beolab penta receiver to clean it for exampel
from dust?
Pag
The Viking
