Beolab Penta light stays green
Hi all
Ive recently had the drivers replaced on my Beolab Penta Mk2, and ever since the green light has stayed on, they work great, look fantastic and operate fine in every other way, They just don't go to standby, i have tried all switches, turning off & on again and its the same behavior with different sources connected
I had a read online and couldn't find anything to help, so if someone here has a suggestion that would be great :)
any suggestions?
Im also looking for part number 9033 which is the little toggle release catch for the front flap is anyone has one :)
I have the EXACT same problem. If you find a fix - please let me know!! 😁
If I find out before you, I will report here and/or my PentaLab thread.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Rob.B wrote:
any suggestions?
Is this the clip you're after?
Beofan for many years with a penchant for 1990s audio systems.
Hi
i also have a pair of penta 2s which have same fault, the drivers have not been done yet, but as you say with yours mine are also working fine apart form whats been mentioned, with what looks like a common fault i think we will get some good info soon from this site.
marc
This has been fixed in the past by changing TR BC337-40
Hi Lee
Would this be for both speakers, how does this fault happen to both speakers at the same time
marc
Hi Marc,
Unfortunately I'm not sure. It's just something I read on an old post.
Lee
