Hi all.
I bought a pair och Pentas today with the displays missing. Since I couldn´t read out the type numbers of the speakers, only for the amps I wasn´t sure just what I had bought. I hade some thoughts that it might be MK3:s since nice MK3 display covers was fitted. After disassembling at home I found out that it seemed to be that a pair of Beovox MK1 (type 6611, serial starts with 05) had been paired with amps MK3 (type 1731).
So, what kind of displays will function? I´d like it to be the green MK3:s since the front covers are the blackish ones. The connection is brown with 6 cables in different colours. No PCB:s in the casing whatsoever =(
Regards, Sven
