Do you know if it is possible for a pair of beolab 18 connected to a beovision with WISA, to be also connected with a powerlink cable to a beocenter 2, or a turntable or any other device?
If yes, how is the experience?
thanks all
There is no way to use Beolab 18 as a “standalone” pair, it always needs to be connected to a source, wireless or wired. In wired use, the aforementioned prioritisation applies. Maybe you’re thinking of Beolab 28 instead, which do have sources built in and behave differently otherwise too?
Certainly I do not ‘mistake’ the 18’s for the 28’s!
But my explanation maybe - for you - was a bit unclear…..sorry for that.
The BL18’s are a pair of speakers!
Also see my post in ….which also contains a link to a posting on Geoff Martins website about the 18’s.
