Thanks for that video and for mentioning it here.
And - since this is your first posting - welcome to Beoworld.
Thanks! I will post more in different threads about the various Beolab and Beosound equipment that my wife and I have collected over the years.
I realise that the Beolab 90 video link didn't show up as a link above, so here it is again
Hmmm...!!!
I really like the guy asking for the name of the speaker 😂 (may be he was just passing by and saw light inside...)
Double post
Thanks Yendys
Hi Fred,
I tried to check the Beolab 90 app and it seems that the Active Room Compensation feature is not yet part of the version 1.6.
So how did your guy was able to do the multiple ARC filters.
G'day zerocool143,
I have two methods for setting ARC. From an Apple device, use the Beolab 90 app. The app has had the ARC configuration for a few months. Geoff Martin's video explains it very nicely. The second method is from an Android device. If you can determine the IP address of your speakers then you can use a Web browser to directly access the software in the speakers and the interface is almost exactly the same as the Apple app.
If you are having difficulty, you might need to make sure you have the latest updates for the speakers. This was provided by (and installed) by the technical people from B&O. They had it on a USB, but it might be available online now.
I hope you can get the ARC sorted as it is the feature I best like about these speakers.
ARC and the BL90 app which sets "the scene" works 100% and is extremely effective unless I'm missing something. Described in detail on YouTube with Geoff Martin.
