Question he has put to me - the speakers are capable of delivering 8200 watts, but ohms law would suggest that to deliver that kind of output a 30 amp supply would be required. If I remember right, the Lab 5s have a plug top fuse rated at 10amps for their 2500 output?
I was advised in Budapest that the speakers would in most cases be run in 'energy saving' mode to avoid the need for a dedicated mains supply capable of 30 amps plus, but it reality, anyone investing £55k won't want to run them in a restricted mode?
Hi Nick,
I'll leave it to Geoff to clarify any details specific to the BL90 (and hopefully to correct me wherever necessary) but will make some comments / observations from an electrical point of view...
Firstly, fused plugs are not commonplace worldwide - the BS1363 UK plug socket arrangement is incredibly well designed from a safety perspective (those who have accidental stood on an upturned UK plug might disagree I suppose!) and the fusing is there largely as a result of the use of 'ring final' circuits in the UK and the fact these tend to be protected by a 32 Amp circuit breaker at the consumer unit as opposed to the more common (internationally) radial circuit arrangement which tends to be fused at 16 Amps or less. The history behind the use of ring circuits in the UK is largely the result of copper shortages, but my aim here is not to give a history lesson but just to make the point that plug top fuse related issues are likely to be largely a UK concern.
Now the fuse itself - A 13A BS1362 'plug top' fuse is required to carry 1.6 times it's rated current (ie 19.8 Amps) indefinitely without rupturing, and is required to rupture within 30 minutes at 1.9 times its rated current (ie 24.7 Amps). Going further it's required to rupture within 1 to 400 seconds at 30 Amps, 0.1 to 20 seconds at 50 Amps, and 0.01 to 0.2 seconds at 100 Amps. The fuse it really there to protect against short circuit scenarios and long term overload situations, and in many cases the 32A circuit breaker in the fuse board is actually likely to trip before the 13A plug top fuse ruptures. The point here is that short transient demands of several times the 13 Amp rating can be accommodated without any issues.
You are correct that 8200 Watts, at 230 Volts, is around 36 Amps - yes I know the mains is *really* 240V in the UK, but we're all harmonised with Europe now so we're officially 230V for calculation purposes 😕 In fact given no amplifier is 100% efficient, the input current would actually be higher that this, but...
I suspect none of the drivers would survive the maximum output of their relevant amplifier for any length of time, certainly the voice coils in the tweeters would melt pretty quickly if subjected to a continuous 300 Watts as that is a lot of heat to try and dissipate. 8200 Watts is roughly equivalent to three or four electric heaters or a fairly decent electric shower. Add it's stereo partner and you'll probably not need to turn your central heating on during winter and you can forget needing to go to a sauna - just stay at home and listen to load music (perhaps whilst wearing ear defenders!).
I guess the obvious question at this stage then is why such large amplifiers? Whilst this is an area Geoff will be much more knowledgable and better qualified to explain that I am, specifying amplifiers that on paper would seem overkill compared to the maximum continuous ratings of the drivers does in fact make a lot of sense - unlike the mains power, music is not (generally) a nice pure sinewave and instead consists of many transient peaks and troughs and the amplifiers need to be rated sufficiently to not clip (cut off the tops of the waveform) during these transient peaks as this leads to distortion and large amounts of energy flowing through the voice coils with no movement of the cones.
There's a common misconception with conventional amplifier plus passive speaker setups that it makes sense to specify speakers that have a higher rating than the amplifier on the basis that it is then impossible to damage the speakers by turning the volume up too high. In reality, this is often a more risky approach than the other way around because as soon as the amplifier starts to clip, a large proportion of the energy ends up heading to the tweeter (at least with the one amplifier, multiple drivers + crossover arrangement).
The bottom line then is that whilst the total rating of all the amplifiers is 8200 Watts, that figure is unlikely to ever be reached except for very short transient spikes and even then the power required to handle these is actually much more likely to come from the capacitors within the power supply than directly from the mains.
Hope this helps,
Martin.
