Beolab 90 - interested in purchase, questions and any owners here?
Hi many thanks for your reply
the ticking is from the master most pronounced on the top section, but can be heard on the woofer ( could be just transfer from internal wiring)
my concern was parts availability in the long term and fixes/getting parts from them may prove difficult
take care John
Normal 0 false false false EN-GB X-NONE X-NONE
i will certainly keep this forum posted on my experience the retailer seems to gloss over the complex scenario of repairs
i just hope Land Rover had nothing to do with these  LOL
sirjohn wrote:
update the clicking is from one of the front facing tweeters that have failed (rather the driver)
My suspicion is that it's the amplifier that has failed rather than the driver.
If so, it's approximately a £250 part and should take less than an hour's labour to replace.
where can i obtain the amp and part number if pos
many thanks for your help
You'd need to go through your B&O dealer for that, unless somebody on here has access to that information. But it should be a pretty simple item to replace.
many thanks will find out what the warranty is worth lol
