very well noted. Will explore the options and thanks for the recommendations.
Beolab 9 using bluesound node (n130)
A quick update:
I borrowed a marantz SR 5006 amp and connected my speakers to the pre-out section of the amp and the results were just as I suspected! The preamp section of the Marantz has better handling/control over my speakers, the sound is more fuller and very detailed.
In some instances i could not believe I was listening to the same speaker set.
in conclusion the node does not drive my speakers optimally and by the time i reach max volume on the node, only now the speakers are starting to open up. I tempted to get newer marantz amp with phono, preamp and streaming services inbuilt ie Tidal/Qobuz.
Regards,
KM
A quick update:
Regards,
KM
