Beolab 9 Speakers
There's very little going on below 30 Hz, and what is happening is definitely not musical. There might be the odd rumble.
To put it musically, the difference between 20 Hz and 30 Hz is around a semitone, the smallest increment in music (excluding music from some cultures). The only instrument capable of reaching below is a pipe organ, and even then I've heard organ music (at a decent volume) on the BeoLab 9s, and they really push out the low frequencies with lots of ease...
i like the rumble effect in movies; will the lab 9's without a sub give you this effect or do i need to use my beolab 2 as well. If i could i would buy lab 5's but i cannot justify the extra cost over the 9's- which to my ears sound really pleasant.
Does anyone know if you can set the cross-over points using a beosystem 3?
Hi Dave,
While bowing to your definitely "mountaineous" knowledge compared to the molehill I've gleaned, I'd like to draw your attention to a few things.
In your paper "Design considerations for an idealized surround sound listening space" you write that in order to achieve best possible room reflection properties:
Loudspeakers need to be at least 6' from any wall or else installed in the wall. (Bottom of page 4, top of page 5. link
In your article "What about BIG studio monitors" you touch upon the need to manage room reflections, and write as follows:
All enclosed spaces have reverberance, except anechoic chambers. Along with the concern with standing waves (which are comparatively easily managed, thank God), the placement of loudspeakers in a room, relative to walls and listeners, seriously affects the low frequency performance of the speaker in the room. There are two primary engineering approaches to dealing with this: (a) mount the speakers in the wall, so that it becomes part of the boundary of the room, or (b) place them far enough into the room that the low frequency interference problems become low enough in frequency to not be an issue. Five feet from the nearest wall would be probably minimum – I know, I know, you’ve still got the floor to worry about, but it turns out that the first null from the floor reflection is usually high enough (ca. 500 Hz.) that it can be dealt with other ways, if you want to bother.
Here you indicate a minimum of five feet - for loudspeakers in general in a listening room.
(Page 3: )
I had a pair of F3 Audiovector which I loved derely, and I changed to BL9. The first month I truly missed the mid range, and had the same experience of metallic highs, and very very deep bass, but no midrange.
This does change over time...!!!!!!! When they have matured you will enjoy the musical picture. Believe me.... They will never sound as Audiovector's but they have their own smooth picture which I trust that you will come to love over time.
The Dane
I often find that a lot of hifi systems seem to have 'too much' midrange. I mean sure, it sounds nice and 'open', but it doesn't sound very natural. As someone who plays multiple instruments daily, I've noticed that what audiophiles in fact think is a very natural sound, is actually a very midrange-biased sound. String ensembles seem to come out worst, usually sounding really 'pushed' and harsh in the mids, wheras this never happens on BL9s/5s/maybe 3s.
Niveau,
I am glad my ears didn't deceive me and that others have discovered it. The problem with letting the speakers "wear in" is that you don't really know what you are going to get until after you have spent the money.
