Beolab 9 or 18
Great photo of the different speakers together in situ. And, hate to say it, but I still think the 8000s are better looking than the 18s, but then I also think the 9s are better looking than the 20s. The amount of sound you get out of the 9s is astounding, especially considering their size. If you look at them, and think about massaging their volume into an equivalent box shaped speaker, you appreciate how truly small they are. There is a fair amount of electronic trickery involved that's apparent if you know something about both how speakers work sans electronic adjustments and how small the cabinet volume is for the woofers on a lot of B&O speakers. Take the 5s, a 15 inch subwoofer in a cabinet of 1.5 cubic foot volume that goes down well below 20 hz! Back in the 60s and 70s you'd need almost a refrigerator sized cabinet for that.
Years ago I encountered a device made called the Bassis. It was an electronic box that, for a sealed enclosure, let you force the driver to have whatever Q, resonance, and low frequency cutoff you desired, limited by the amount of power you had and how robust the driver was to handle the excursion and power. Since back then not many drivers in production speakers were not that robust there were limits to what you could accomplish, if you look at the woofers on the 5s or 9s you can tell they are very robustly designed and constructed to handle the boost and such. I find this a remarkably intelligent design approach, in general and especially for a company that desired to produce livably sized speakers with good bass response.
Hi everyone.
Thanks for your advises. I will go for the Beolab 9s. Heard them at a shop and they sounded amazing and not boomy as I feared. Were open sound.
Brgds Mogens
I agree on all counts.
Of the "new" generation speakers, I do like the look of the BL90s though -- they're the size of a small refrigerator :-)
Well it took 2 years before I got them but now I have a set beolab 9 in my living room. 🙂. They are connected to my BeoVision 11 together with a set of beolab 6000 as rear. Just wondering if i have set it up correctly. My sofa is app 3 meters from the beolab 9 and 5 meters from the beolab 6000. I
Have inserted the distances and all ind the menu but what about the dB setting? How do I determine what figure to put in? Also. I would like to connect a CD player to my BeoVision. Is a beosound 9000 via the s/p dif a good solution ?
Congratulations on the purchase. I’m sure they were worth the wait. I remember this thread when it first appeared and it feels like six months not two years ago!
Can we have a pic please?
It’s a good solution but only sound from the CD will pass that way. AUX and FM is analogue only.
Congrats. I still enjoy our BL9, both for music and for movies. They have plenty of bass for movies!
Hi
Would love to, but can´t figure out how to upload pics.
Mogens
Hello everyone,
I bought my 9 Labs this Monday, this was one of the threads that made me go after a pair.
I was using the Penta Plus BL2 or BL8000 plus BL2, I love both sets, but my wife hates the Pentas design (let's try to understand).
I tested BL9 in my place with and without BL2, after some position and configuration testing, I get my opinion/decision, BL9 is great, plus BL2 is outstanding!
I am very happy, indeed, at this time at 3h30 am. I am listening to Sade and relaxing (only BL9), soft and clear.
Best regards to all.
Hello everyone,
I am very happy, indeed, at this time, at 3:30 am. I am listening to Sade and relaxing (only BL9), soft and clear.
