I have been thinking of replacing my rear 4000s with a pair of 9s. I decided to connect my 9s in the rear to see how they sounded. Unfortunately I get a loud buzzing. My thought is perhaps the power link cable?
My connection is as follows: Power Link from BV7 to in wall Panamax unit. That Power Link does not have a triangle on it (not a Mark 3?) That in wall Panamax unit is then connected by in wall wiring to the rear in wall Panamax units. The wiring connecting these is a coarse purple covered Power Link cable. From the rear in wall Panamax unit a Power Link with a triangle on it (Mark 3?)
Do I need a Mark 3 from TV to wall also and what about the purple in wall wiring? Is it Mark 3 compatible or not? It was installed in 2004.
Or is there some other cause for the buzzing? Thanks!
