My B&O dealer told me that when you choose "subwoofer off", the "subwoofer channel" is distributed to the two front speakers.Ok but someone said if you even have BL5 you need BL2 in a cinema setup 5.1??
Those people probably are deaf! 😎 Beolab 5's have bigger bass drivers and more powerful amps than the Beolab 2 and are more accurate. Beolab 5's produce enough bass for use in a home cinema setup, if you ask me.
I mean more that in cinema setup you have a separate channel for sub, and there will not BL5/9 help or?
I previously had BL6000 as front speakers with a KEF subwoofer. I was very happy with it, but bought the BL5 a couple of years ago any way. At first i was a bit disappointed with the bass, but the B&O people had forgotten to set the subwoofer to "none". After I turned the subwoofer to "none" the BL5 came to life.
Adding a BL2 to the BL5 doesn´t sound like a good idea. Not to BL9 either, after what I´m told from B&O.
