Beolab 8000's will the work via a non B+O Amp ?
Hi All
my first Question on here Guy's so please be gentle ;)
 i have a acquired a set of Beolab  4000+8000 + a beovision 7 '32' mk3 + Overture
 i am listening via the overture but would like to add to my 7.1 setup i am in the process of getting a new Amp
Onkyo TX-NR818 is there a 12v Trigger Req ? for powering up Speakers
any Help Much Appreciated
The 8000s (and 4000s, too) have a RCA line in.  You need a variable line-out (from a pre-amp).  I believe the speakers are line sensing so no trigger voltage is required.
Welcome, btw.  Mostly friendly folks round here.
http://soundsheavenly.com/line-in-connection/33--attenuator-.html
Speaking of friendly, Steve is the source for cables.
I have to correct Peter, Steve is the FRIENDLY source for cables😁
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
You should use triggers in a min. 5.1 setup to avoid that the speakers turn off in low volume/no signal szenarios.
Please search for 5.1 setup with non B&O AVR on this forum.
Posting this from a smartphone, so only limited capabilities to support you.
Can try later....
Best regards
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thanks Søren for clarifying my participle phrase with a simple adjective. 😕
Does anyone know why they eliminated the LINE in socket on the BL4000 Mk II (ICE) version?   There is still a switch position labelled LINE.  e.g.
[quote user="MediaBobNY"]Does anyone know why they eliminated the LINE in socket on the BL4000 Mk II (ICE) version?   There is still a switch position labelled LINE.  e.g.
