BeoLab 8000s HELP!
yes it is a 3.5 jack to 2 rca.
yes my mac is configerd for output line
I have tryed 2 diffrent cables for the 3.5 jack to 2 rca on both imac and ipod
I have tryed just using a cd player right into the 8000s and no sound
I have tryed pluging a amp into it (marantz amp) with a cd player and that did not work
I have tested the rca cables and all do work.
yes speakers are set to line input witch is all the way at the bottom
with out any cables pluged in the lights on both stay on green.
thanks for your hep guys I really appreciate!
Something is wrong with your speakers, without soundcables connected the light should be red, just tested on my 8000s,  rca out red light, rca in with sound green light.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Ah ok I see, sounds about right, knowing my luck!!!
I was doing some reading about it, does your relay click when you turn your 8000s on?
thanks so much for that info! :)
My speakers does not click when I turn on the power, (or I cant hear it because of my switch clicking)but when sound comes or no sound for 1=2 minutes I hear a wery low clicking sound (stand by relae)
Retired
Rock and Roll music
Collecting Vinyl
Alright thank you for that info.
I think im going to open them up and see if there is anything burnt out on the inside and go from there..
thanks for your help :)
if there is any one out there with any more info on what the problem might be would be good if you could tell me please :)
Keep your head cool now. If you are going to open them, you pretty much lose all justification of getting refunds or something, as it will be impossible to show how the possible damage happened (it will be obvious that they have been opened - there's a lot of sealing that will be damaged).
Also, you will not become much wiser by just eyeballing the innards. If they both have a fault in the signal sense system (which I still can't believe), it's not going to be something that went up in smoke.
Also, your problem statements are a bit controversial as Soren already noted... are the leds green or red, as you have said both already?
Let's get back to organized troubleshooting:
  • Unplug from mains
  • Disconnect all signal cables
  • Turn the switch to L or R (Powerlink input)
  • Plug in mains
  • The LED should be turn on red and remain red
Next...
  • Unplug from mains
  • Turn the switch to LINE (RCA input)
  • Connect an RCA cable or your iPod cable
  • Plug in mains
  • The LED should be red, or possibly turn to green right away if the cable picks up enough interference
  • Touch the center connector of the RCA cable (or tip / center ring of 3.5mm plug) with your finger
  • The LED should turn green as the speaker powers up and you should hear a healthy loud buzz
Alright I will keep my head cool for now :)
I can't get a refund anyways But yes I understand what you are saying
Oh alright, I will not pull them apart then.
yes that was a misstake on my part and I did have both set to middle witch ment they were both on right. I do know now where left, right and rca is.
Step 1. beolink
I had one set to left and the other set to right and all cables were discontcted and I followed your instuctions and both lights are staying in red.
pluging in the beolink cables with nothing conected to them stays green for 30sec then turns red
Step 2. RCA
unpluged all cables then plug in mains = green lights
pluged in just rca with no i pod  then plug in mains = green lights
pluged in rca to ipod then plug in mains = green lights
Touching the tip of the plug does nothing at all, there is no huming or buzzing.
thanks so much :)
OK, that makes more sense - we can now guess further 🙂
Seems like the signal sense circuitry is working, as they stay in standby in Powerlink mode with nothing connected, and turn on with a cable connected (due to stray interference I suppose).
It could be that the signal path from the RCA connector is broken either at the connector or the selector switch. It is odd that both speakers would be like that... It is also strange that you don't hear any kind of hum or buzz with the cable end open, though. I believe we are ready to ditch the seller's claim that they worked 🙁
The thing is these speakers have two power supplies. The standby power supply, which is on all the time, keeps the signal sense circuitry powered which also controls the indicator LED. When it sees incoming audio (or the Powerlink power on signal) it pulls a relay, which turns on the main power supply to the amplifiers. You should hear the relay click when the speaker turns on & off; unfortunately it isn't too loud and is buried inside the metal casing, so it isn't quite easy.
After that, there is still a thermal fuse for the main supply transformer and two fuses on its secondary... any of these could be blown, preventing the amp from getting power. But once again I wonder how it could be the problem on both of the speakers.
BTW the switch is up L, middle R, down RCA.
Thanks for all that info Tournedos :)
wow so it's stll a few things that it could be,
so would you have any advise what I should do from here?
is there any more tests that i can do to troubleshoot this..
this guy here http://forum.beoworld.org/forums/t/33488.aspx seemed to have the same problem as mine, as my ones were put away in a box for a year or so..
I pretty much agree with that other thread - I can't think of much else to try outside the speakers any more.
I've never heard of the EQ board coming loose problem, but that wouldn't be a first 🙂
If you decide to open them yourself, be careful. I didn't need a knife with mine, but the amp module sits quite tightly in the gasket material and will appear glued in (because that's what it essentially is) even after you remove the screws. Furthermore, it's very heavy (probably 2-3 kg) and the wiring looms inside have very little loose length. Lay the speaker down on its back so you don't rip anything off when the module decides to let go.
