Many thanks for your advice.I have ordered the damping material through a dealer as you suggested.
Once both 8000's are fixed, I will check my pair of Beolab 6000's. According to the dealer, these seem to often suffer from damage to the rubber speaker surrounds. There is quite some info available on the web as well as repair kits. To be continued!
