Yes, I did the cleaning myself. Not a task I like to do (understatement ;-)
For the cleaning I would recommend not to use chemicals. I never do with vintage audio equipment. I always look for eco/biological cleaning products.
The BeoLab 8000 (and other) speakers are made from aluminum and anodized. Anodizing creates a layer that makes them shine like chrome. But this layer can be very sensitive to chemicals. When it is damaged or gone because of treatment with the wrong materials, there is no way back (or you should anodize them again which is quite expensive).
So for the outside I mostly use an eco-friendly degreaser from a spray bottle. Read the label to make sure there are no chemicals added!
For the inside I use the same principle; no added chemicals. But the story is different because you have to get the sticky foam out. And it is very sticky. Here's what I do:
- Use a table covered with plastic you can throw away (so if pieces of the sticky foam fall, you keep them on the plastic). Put the BeoLab on the plastic covered table. Use plastic hand gloves to keep your hands clean.
- Remove both the 'power supply/amp' and the 'speaker panel' units from the speaker casing.
- Start taking out the big foam pieces by hand, from bigger to smaller. Be carefull as they easily fall apart. I stopped using a vacuum cleaner, as the sticky parts maken it constipated, and you can throw away the vacuum cleaner. Make sure you also remove the foam pieces on and in between the components, and from the PCB's (both the component side as the side with the copper traces).
- Clean the last foam remains on the PCB/components using isopropyl alcohol (96% or up). I mainly use ear tips for this. This part is also time consuming.
- What is left is cleaning the inside of the empty speaker casing, the aluminum part. To get rid of the last foam remains, I use natural vinegar and an old cloth. If you use the right vinegar, there are no chemicals in it. And vinegar is able to dissolve the stickyness of the foam remains.
Again, it is a lot of work. But it is do-able. Anyhow, not doing it with old BeoLabs that have this sticky foam, means high risk of a beautiful speaker that will get serious issues.
If you have PCB traces that are already eaten away, you will have to create a new trace. You can easily do that by using a wire. Normally you can see where the trace is supposed to be, so you solder the wire in such way that you reconnect the components that are in the PCB trace. I have had situations where the Auto Standby relais was malfunctioning because of this. Be aware that sometimes a PCB trace looks fine, but if you use a magnifying glass you can see that is partly 'eaten away'.
Hope this helps you.
