I'm relatively new to the B&O audio world by getting first exposed to the high fidelity found in my Audi S8, which I'm told leverages the B&O BeoLab 5 reference architecture.
This has finally prompted me to upgrade the audio in my living room. While the BeoLab 5 would be ideal it's a bit too pricey at this point.
Currently our living room has a Bose Acoustimass Cinemates (yes, I'm hearing the laughter from you!) which had been decent but no longer.
8000's have a timeless design and are a great value second hand and are priced about the same as a new S8. I also like the way the 8000's look much better than the BeoLab 3.
The plan is to get either one of these and connect them into our Samsung TV audio in 3.5mm jack to simplify TV volume up & down controls for the rest of the family. Seems like adding in a DAC might complicate things for folks in our household? As you can tell our audio needs are pretty straightforward. Everything pretty much drives off of our TV or off of Apple AirPlay/AirPort.
Currently I'm leaning towards the 8000's but then I have also seen some people complain about there not being enough bass which then leans me now a bit towards the S8's. My guess is that most everyone here will steer me towards an 8000 since the S8 is so new/entry level and it likely will be half the price a year from now?
Part of me considered the BeoLab 3's but then it also felt a little incomplete with out the BeoLab 2's and it doesn't look nearly as good as the 8000's. The one thing the S8 has in the looks department is that it feels directionally similar to the BeoLab 5, which is a good thing in my mind too especially if i eventually want to get that.
Would love to hear how folks would think through these possibilities with all your relevant experience.
Thanks,
Humphrey
