Beolab 8000 or Beolab Penta for Movie/Music
I tell you what, buy an old apple tv... any generation...
Plug all your speakers into your TV. Plug the apple tv in via HDMI and then you’re all set to airplay from anywhere and use to screen mirror!
Only problem here is that your TV will need to be switched on to hear the music...
Both the Pentas and BL-8000s are great speakers. I own both and have had them for well over 20 years. The Pentas will give you adequate bass but are not as crisp on the high frequencies like the BL-8000. Of course, a pair of BL-8000 paired with a Beolab 2 or Beolab 11 subwoofer would take care of the bass. One member indicated that there are problems with the BL-8000s as they age. I'm not sure what he means by that, as I have owned mine since 1993 and one needed a new transformer at one point, but that is not a common issue. The smaller BL-6000s have a known issue with foam rot around the woofers. I had to perform this repair on my BL-6000 speakers a few years ago but never experienced this problem with the 8000s, which I have owned for years longer. My Pentas have been problem-free since 1996.
Also, Pentas have a fragile, stainless steel finish. They can be easily dented and show every fingerprint. Personally, I think the BL-8000 is a more iconic and timeless design and is my all-around favorite.
I vote for the 8000 as well, at one point in time, (actually not long ago), I have considered replacing the 8000 with focal, but the look of two black boxes vs the slim 8000 is no comparison at all. Am keeping the 8000(gold color) until I replacing them with BL 5. Then I will move the 8000 into the bedroom. :)
The main reason why I started to look into Beolab speakers is due to the design of Beolab 8000.
Pentas is probably due to its bass, but as you describe Pentas is a bit more fragile in terms of the product quality.
Start with Beolab 8000 as a start and add Beolab 2 or 11 or even other brands sub can be a good idea.
Then it is what receiver I should use, sonos connect seems lack of sub output, bluesound node 2 can be an option.
That is really a good example how the design of the speaker can save its life.
The reason of dropping my linn Ninka is also due to the outlook of it.
May I ask how you use BL 8000 in your setup?
Get a Beosystem 3 πŸ˜• 😁
Good choice but over my budget.
I Google airport express and the output is a combination of mini toslink and analog output so it can use 3.5 mm to rca cable.
I use the BL8000 as front L and R connect to the pre out of the Pioneer LX83 using modified 9pins (was it 9 pins?) and 12v trigger. The same way I used to connect the BL 2 and BL4000. Only the BL 10 that need 7v trigger have I used a dedicated trigger box.
I have been using the whole setup for almost 10years and only one 4000 had failed me and send back for an amp replaced. The only real problem I have is the tacky sticky finishing on the BL10 and the BL2.
I have found the 8000 sounds a bit sharp to my ears and I have to play around the EQ on the Pioneer. It's getting closer to what I like, but am still fine tuning. 😁
