Beolab 8000 or Beolab Penta for Movie/Music
I have never owned a pair of Pentas and can't remember how they sound so not able to comment on these specifically. However, I have owned a pair of Mk 1 and Mk 2 BeoLab 8000s with a BeoLab 2 sub and I was extremely satisfied with the look and sound reproduction of this setup for movies and for music. I only used the sub with movies.
As a design statement, together they looked and still to this day look very modern and contemporary adding a real statement to whichever room they are placed in. I was more than happy with the sub for bass; in fact,i t was far too overpowering on many occasions but in a good way, I just didn't make use of it to that depth.
As for the BL8000s when playing music, well to my ears they produced a truly wonderful sound and I was often blown away by them. I would therefore wholeheartedly recommend such a setup. All the best and what a fantastic position to be in. Enjoy whichever route you choose, I am sure you'll be so happy either way. Simon.
Hello Simon,
Thanks for your good comments.
I just called local repair store and had a chat with them.
The guy suggests to use Beolab 8000 + one Beolab 2 + Beosound core. Beosound core has wireless connection and connect the Beolab2. Then from Beolab 2, one connects two Beolab 8000. But this system is above my budget, especially Beosound core which is hard to find in the second hand market. It means that I need to buy the new one. I was thinking to have sonos connect but it lacks sub output. Bluesound node 2 is an option. How do you set up your system? How to connect the whole system for movie and music? I am interested in the detail setup here. ^-^
By the way, what is the difference between MK1 and MK2 in your opinion?
Why do you need the core?
How do you listen to music? If it’s streamed from your mobile or tablet then why don’t you buy an apple airport express and use this as airplay? Or chromecast audio...
The speakers obviously need to be connected to the TV as you want to enjoy your movies...
Your TV needs some sort of input for the streamers (airplay, chromecast)...
What TV do you have?...
Go slow...
Don’t buy anything just for the sake of it... save over some time if you have to...
Have a look below...
ALMANDO
Hello Kiran,
I use iMac or phone to stream music wirelessly. At least,  this is what I like to play music.
I have looked airport express solution, then you will connect 3.5 mm socket to RCA inputs in Beolab 8000. I am not sure the quality of sound in this setup.
TV only has coax output but I may upgrade my TV.
Upgrade your TV!!!
The airport expresses are only £10-£15 on ebay.
The quality is great! There is no loss and you will not be disappointed. You can Airplay from anywhere which I think you already know about as long as you’re connected at home...
I have 3 expresses which will ultimately go into 3 NL/ML Converters... 👍🏻💯
If you plugged the RCA into the 8000, will the Powerlink work too?
I have never tried more than 1 connection to Beolab speakers...
Do you use 3.5 mm to rca cable?
No... Powerlink to 3.5 and Powerlink to RCA
I will use the 3.5 to RCA for the new connections... from the airport express to the NL/ML...
I used to use the AUX from various BeoSound systems to my iPhone...
All my systems are in bits while my house is being done...
I won’t be using AUX anymore. I will be using the Line-In on the NL/ML converters to distribute 3 airport expresses around the house... (I have around 10 BL3500 for this)
Allright.
I dont have  NL/ML and a bit confused about all the setting here.🙁
