Beolab 8000 hums ...
Hello B&O community,
since today one of our Beolab 8000s hums when it is switched on
disgusting in "felt" 50 Hertz (network) frequency ...
I suspect the power supply capacitors, or am I lying
possibly completely wrong ...?
I have the service manual and I can handle the measuring device and soldering iron.
Thank you for constructive information
Greetings from Merlin
It could be a faulty/damaged powerlink cable. It’s easy to check, just switch the cables to see if the problem remain on the same speaker.
Hi Daniel ,
thank you for your quick reply. I tried 2 other Powerlink cables ...
unfortunately no improvement can be heard.
Nevertheless, thank you again for your help and
greetings from Merlin to Sweden
OK, sorry it didn’t help. That’s where my knowledge ends, so I hope someone else can help you more.
