Beolab 8000
Good afternoon.
I have a Beolab 8000 (with Beomaster 6500, Beogram CD 7000 and Beogram 5005). When I am playing some CD's or long plays (not all), the BL8000 speakers sometimes do not play all the music correctly. Sometimes the vocals don't sound or sometimes the guitars don't sound.
I would be grateful if anyone has this problem and how I can solve it.
Thank you very much.
It sounds like you may have both of your speakers set to the same stereo channel. Check the switches on the back of each speaker, and make certain that one is set to L and the other is set to R.
Hello,
I have followed your instructions and the problem has been solved.
Very kind and thank you very much.
Antonio
Glad it worked out! You're welcome.
