Beolab 7.2 with HDMI ARC
I've tried this solution with a Samsung LCD, about a year old. I got only full volume audio from the extractor. I've used 2 different extractors and these weren't cheap. Both were from the brand Marmitek.
The Samsung was a 43RU7100. It was a very unstable setup. I've fiddled for hours. The idea was to connect a set of BL6000's via the extractor to the Samsung. But I ended up with an extra BM6500. Not the best idea I had in mind.
So, I assume that it differs from brand to brand. It seems after a lot of reading that every brand has it's own thought which sound they put through the extractor. There are examples that the sound of the tv itself goes through the extractor, but sound from some apps don't, like Netflix or Spotify.
RealHippo wrote:
I figured out that it was the power supply I used that introduced the hum. I changed it another 5v 2a charger and the him disappeared.
I have also changed from headphone output to the RCA output. The sound is much much better and volume regulation is a lot smoother. You don't get that big difference in volume with every click like with the headphone out.
I also changed to the rca output. No hum, but like you say the steps are bigger. But I am very happy with this now 😀
Great way to upcycle the BL7.x’s 😁
Maybe you can help me out. I have put the Marmitek AE24 ARC Extractor between my LG 49UM7100PLB and my BeoLab 7.1, .but the only problem is that I've got MAX volume output and I can't regulate the volume with the LG TV remote control...any advise?
WhauWWW, what a beautiful solution @leosgonewild Compliments!!!
The B&O Tv stand gives so much freedom (furniture placement) in the living room.
I currently have two 8000's (I sold the BL2 a while ago, replaced it with a B&W asw610, which integrates better, separate eq control, etc.) connected to a B&O Playmaker and the Playmaker with a rca to spdif converter to my LG C9 Oled.
I controll the volume with my BEO 4.
Works well and sound quality is good.
I'm planning to change my setup (I made a 'wall' myself, see photo, but on photo still with my old Philips tv), removing the wall and place my LG 55" C9 Oled on a B&O (motorized?) stand, freely in the living room, upgrading with a 7.1/7.2 an two rear speakers (maybe beolab 3), to create 5.0/5.1 surround. Don't know how, maybe with a Almando surround module (I'm making another topic about this question).
Can you tell me how you made the B&O stand with the LG Oled tv?
What model stand would I need, for the 55" Oled?
And would a motorized model be possible? How to control it?
What model Arc audio extractor did you buy (aliexpress?)
Leo???
And what about the quality of the sound? How is the internal dac from such a 'cheap' arc converter?
I bought the same box but had to return it - not stable at all.
Hallo tuttivini. You can solve the problem like that. 🤒
@Peter Pan: What a great 'photoshop'. Compliments 😁
In fact, I had a 'similar' setup, like you described/drawed, in the past.
Because I didn't like the looks of a big av-receiver on the shelf, I placed a Marantz NR av receiver, floating underneath the shelf.
This worked great, but changed to a B&O playmaker, because of the good internal dac, simplicity, control volume with beo4 and cleaner looks, auto sensing/switching inputs, etc. (Playmaker hidden underneath the shelf).
This pleased me for the last years, but always wanted a better centre-channel sound/voices coming from the 'screen'.
So bought a Beolab 7.1 last week (this topic: link)
Already made my own bracket to hang it underneath the tv.
I'm making the 7.1 silver speaker-grill the same look as the 8000's this weekend (using same speaker cloth). Will post pictures.
Playing 'double stereo': 7.1 and 8000's both connected to the Playmaker (and a B&W subwoofer).
And possibly going to upgrade to real 3.1 surround, when I find the right small surround decoder ( Almando, Canton Smart 5.1, etc, like asked in this topic:  )
Here a photo of my former setup with the AV-receiver floating under the shelf...:
@ tuttivini. I hope you find the right solution for you. 🤒
That is the unit I used.
To make a bracket, just get a metal plate and measure where the holes need to be 😀
