Beolab 6000 Wall brackets !
 Does anyone have these kind of brackets ? I heard that B&O already put them on the market.
 They look very good against the walls. Do you guys have something like this on your homes ?
 Can anyone post some images if you do ?
Thx,
Stefan
Check out
My dealer has a pair,
AND they look absolutely stunning!!!
sorry, have no pic.....
Yep, a mate of mine has his mounted on the wall. They look pretty cool  I must say.
Jonnie
Thank you for your replies guys
Tried to look them on E-bay but didn't found anything. :P
Regards,
Stefan
image of Beolab 6000 wall bracket
I've had a pair for a while now. Solid aluminium. £190 a pair I seem to remember!
Hi, I installed a pair of the 6000 wall brackets for a client recently and I had mixed feelings about them.
Plus: They look GREAT and are really nicely made in solid aluminium.  The Lab 6000's look very good on the wall!
Minus: Cost nearly £200 UK (Ouch!), also the speakers can't be rotated on the brackets, so they are fixed parallel to your wall.
I personally wouldn't spend that amount of money on a pair of wall brackets that can't be adjusted, but it's your call!
Best regards, Steve.
Hi all,
 Glad to see you again Steve.
 Thx for your opinions guys. I will start a new thread regarding the best positioning for my system.
 You are invited to post there about this.
Regards,
Stefan
