Beolab 6000 to Beomaster 3000
Hi hejsam,
Yes, I understand!  Unfortunately, I have never seen a good quality, shielded male RJ45 to twin female RJ45 socket adapter.  Hence, the best option is the male RJ45 to twin female DIN adapter that we discussed already, then you can use an RJ45 to DIN cable to connect from one socket of this adapter to the Beoplay S8:-
link
You can use a normal DIN to DIN Powerlink from the other socket of the adapter to the first Beolab 6000 and another one between the two rear speakers:-
Hi Steve,
I have tried all of the different suggestions you gave me (got them from the swedish website).
Unfortunately none of the ideas worked, seems it´s impossible to get the Beoplay S8 to give out sound to both the original sattelite speakers and the beola 6000 speakers at the same time..
I got sound from all speakers by one solution but a really loud humm from the speakers all the time (while not playing).
Hi hejsam,
If you bought the cables from a different seller, they may not be correct for your needs (did the other seller confirm suitability?)  My cables won't cause any humming noises, as they will be correctly wired for your equipment.
I would suggest contacting the other seller to see if he has sold you the correct items, you should be entitled to a refund under EU selling regulations.
Kind regards, Steve.
So think the cables are the problem?
They were cables specificly made for B&O..
Okay so lets sum this up, if you were providing me with the cables which setup would you made me do?
I have the Beoplay S8 (2nd generation) with the 2 original sattelite speakers and the connection hub, the whole system only got 1 line-out (from the connection hub to the subwoofer).
I want to add 2 more speakers to the system, a pair of Beolab 6000. I want everything to work (including adjusting the volume on the whole system from the connection hub). And no humming or interferance.
Thanks again
Thanks again
Hi hejsam,
I can't comment on cables that another seller has provided, but there should not be any humming noise if the cables are wired correctly.  Please see my replies in the thread above for links to the correct items to connect all three speakers to the single output of the Hub, with volume control from the Hub for all speakers, without any humming issues.
Thank you, I will try and order your cables instead.
Is it this answear you are refering to? :)
Hi hejsam,
Sorry, I mean to copy this answear:
Hi hejsam,
Hi hejsam,
Yes, please use these cables that we discussed and also this RJ45 to twin female DIN splitter:-
