Beolab 6000 Speakers
I'm looking to buy a pair of Beolab 6000 Speakers. The seller tells me that the leads are fitted with 8 pin Din connectors. I want to use these with my Beomaster 901 tuner/amplifier, but it has what I think are 2 pin Din sockets.
Firstly, are the speakers and amp compatible, and is it easy to connect the leads if I bought a couple of 2 pin Din's? I'm not that good at soldering!
As a supplementary question, what was the range of speakers that would have been bought with Beomaster back in the day?
The BeoLab 6000’s are active speakers - meaning that they each have an amplifier built-in.
They need an unpowered, a line signal - the 901 has only ordinary L/R speaker outputs....they are from another generation.
What you’d need for an amp/tuner like the 901 is a set of passive speakers.
Any set will do - but not any set will be ‘good’.
If you are looking for a set from B&O, please have a look on the product archive pages on Beoworld.
I am sure there is someone on Beoworld with experience of the BeoMaster 901, who could tell you which speakers are best suited.
You should however, if you choose some aged speakers look out for the condition of e.g. the drivers.
They are not compatible.
Beomaster 901 was built for passive speakers.
Beolab 6000 are active speakers (they have built-in amplifiers).
Suitable speakers for your Beomaster 901 would be any of the models in the Beovox range from the late 1960s to the early 1990s.
Beovox S45 would be an excellent choice, but also the smaller Beovox S30 (Type 6301), Beovox 1100 or the panel versions Beovox P30 or P45.
Beomaster 901 was often shown with Beovox 901 (or Beovox 1001) speakers, which are both special and somewhat rare, but the
above mentioned models are (in my opinion) better speakers and easier to find.
Hi endean0,
Welcome to Beoworld!
Please don't worry, whilst officially these speakers weren't designed to be used with your Beomaster, they can be made to work well together.
The key is to reduce the amplified speaker outputs of the Beomaster to a variable line level that the speakers can accept.
To achieve this, please connect two speakers to the 2 pin DIN speaker terminals on the back of the Beomaster using this Attenuated Converter:
I can confirm that the attenuator suggested by Steve works very well — I have a 1970s quadraphonic Beomaster 6000 feeding BeoLab 90s and BeoLab 5s. B&O claimed that this setup could not be made to work, but Geoff Martin assured me it could, and with Steve's help we made it happen.
My mind is finally blown!! You use Beolab 90s and Beolab 5s with a quad 6000?! I confess that if doing this, (and my mind has not recovered to work out why I would do this!) I would have tried bypassing the power amplifiers which are one of the weak points of the amplifier. Of course the damage is limited by the large impedance that is being driven using the attenuator, but it would remove some of the superfluous circuitry!
Getting back to the original thought, the S45s will sound much better than the 6000s anyway - described by T. Jarman  as a pair of car speakers mounted in a drain pipe - only the tuning work done by the likes of Geoff allow it to function to any degree worthy of B&O. Hope they are cheap!
Peter
I entirely agree with Peter on the BL6000s. The sound quality I find to be mediocre at best. We originally bought them as surround (rear) speakers, and I’ve never been tempted to use them for anything more critical. In fact, I now use BL4000s in preference to them.
Lawrence
4000s are really rather good! In the old days, every room in Struer seemed to have a pair! Have a couple of pairs - the earlier class A/B rather than the ICE power ones.
Peter
Hi Peter,
I have a pair in silver (natural aluminium) and a pair in red - the latter being my favourite 😁
They’re both Mk1 as well. Amazingly, still working. I fear the foam rot inside will eventually get them...
Lawrence
