beolab 6000 only comes on intermittently, sometimes crackling from tweeter
hello beos, anybody out there?
i have a beolab 6000 that initially powers up "green light" via power link, then after use for a some minutes will not power up again (stays on red led) if turned on and off.
if i turn it to line input it hums.
also the tweeter occasionally has a crackling sound like interference for a few seconds then disappears. i have tried another tweeter (same).
i looked everywhere but no posts on this.
any help much appreciated!
greets from berlin
so it sounds like i found it! diode 11 had a dry (badly soldered joint), soldered it and the problem seems to be gone. always amazes me how many bad solder joints one finds in b&o products ;)
Hello Phonic,
I have the same Problem with one tweeter, cracks and dissappears.
Where can I found the Diode 11? What are the steps for disassembling?
Greetings from the sunny Upperbavaria
Antwort gerne auch in deutsch (kurt.breitbarth@gmx.de)
