I have a pair of Beolab 6000 speakers. I have bought new woofers but need to replace the double sided tape that holds them in place. Does anyone know exactly which type I need & where to buy it from? Thanks.
Beolab 6000 double sided woofer tape.
They should be held in with self tapping screws!
OP is talking about the gaskets.
There are no gaskets unless you mean the lengths of black drought excluder between the woofers.
