Beolab 6000
Hello there,
Would anyone know how i can remove tape marks from my beolab 6000s where the previous owner taped the frets onto the body. There isnt any sticky residue, just 2 marks where the top and bottom of the tape were.
Your help would be much appreciated as this has been bugging me for a while.
Hi Ronnie,
Just use a little metal polish on them, such as Brasso/Duraglit or even some Autoglym metal polish (intended for car chrome).
I've also read about a metal polish on beoworld called 'Autosol cleaner' which I'm sure would be fine too.
Regards,
Bentleyman wrote:
Hi Ronnie,
Regards,
Please DON'T! If you try to polish them, you will destroy the anodization! - And that will ruin the finish completely! Do only clean the speakers as recommended in the manual:
- Dennis
Hi Dennis,
Apologies, I've just realised that I was thinking about the stainless steel finish on Beolab Penta's.
I've cleaned the metal on my Penta's with 'Brasso' numerous times and they come up like new. I also remember reading a thread quite recently about the use of 'Autosol Cleaner' - perhaps this was in relation to the Penta's also.....?
The type of metal finish on the 6000's etc. I assume is very different and metal polish should not be used...? I had a pair of 6000's for years - but can never remember cleaning them! apart from regular dusting that is.
My apologies to Ronnie!! 😳 best just using a damp cloth on your 6000's then, I stand corrected! lol
@Michael (Bentleyman)
We all make mistakes sometimes - It's just good that we have each other to say stop before it is (could be) too late. 🙂 It is also a benefit having people from so many parts of the world on this site - There is always someone awake and online! 😕
AFAIK are the stainless stell panels on the Pentas protected with clearcoat. I have always used a product made especially for stainless steel on my Penta's - It cleans and protects, but as the Pentas are clearcoated I don't really think, that it matters on them with the extra protection... 🙂 When you use the Brasso, is it then turning black when you polish? I tried to polish the stainless steel panel on a scrathed Beolink 7000 I have, but nothing happened. My father then told me that he seems to remember, that it also it protected with clearcoat.
The Beolab 6000's are made of aluminium, and they are anodized. The different colours you see on fx Beolab 6000's, 8000's, 1's, 4000's and so on is the
Hello Dennis,
Yes, the brasso polish stuff does tend to turn a darker colour when used. Depending on how dirty the object is I think. When polishing my Penta's with, it went a darker colour and removed the usual fingerprint marks as intended, but as the speaker cabinets were not 'very' dirty to begin with, the Brasso didnt turn black exactly, just a slightly darker shade. I then used a damp cloth to wipe and buff up the panels.
As for the plate on a BL7000, I have never tried polish on that, I'm not sure the chrome touch plate on a BL7000 is the same surface as the Pentas body....?
Regards,
Hmm... The service manual does only say 'Top plate'...  I have always just heard it mentioned as 'the steel plate'... Could someone help here? 🙂
- Dennis
Yes, top plate, steel plate, touch plate, I've heard it referred to all these as well.
I think the BL7000's top/touch plate is of a more mirrored, super shiny, chrome surface plate, whereas the Penta's stainless steel panels are not intended to be quite as shiny and flawless as this. Still shiny yes, but not quite as mirrored finish as the BL7000's plate....
If you look at the Penta's stainless steel very very closely you will see a sort of grain in the actual metal surface, whereas the BL's touch plate is intended to be a flawless chromium finish, like glass of a mirror.
Perhaps someone can clarify further...?
Regards,
Thanks everyone for your help and i shant use any abrasives on my speakers, but what should i use instead, that wouldnt ruin the finish?
And yes Bentleyman the finish is like a mirror
To remove the old tape marks, you might try using a non-abrasive, liquid car wax on a micro fiber cloth. A small dab is all you should try. This should dissolve the old tape residue without wearing down the clearcoat over the aluminum finish. Don't rub too hard, but just enough to get the marks off. You should treat the surface of a BL-6000 speaker like that of a clearcoat finish on an exotic sports car.
