Beolab 5000 grill cover question
I recently purchased a pair of Beolab 5000's but unfortunately on one of the speakers the grill material is torn. Does anybody where I could go to purchase replacement grill cover material? I'm fairly certain it will be impossible to find OEM material which leads me to my next question, how much will replacing the grill covers with non-OEM material affect the value? Functionally they are terrific, I can't tell you how much I love the sound of these. Condition otherwise is excellent. Thanks very much for any suggestions.
Basically it is whatever is available to you and/or what you want to use. Needs to be acoustically transparent (can see light through it). I hear, in the US, that JoAnn fabrics has some offerings. I think it would be a good idea to keep the original fabric to have them available for the reason of being "correct" and so that your value will not decrease.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Hello,
You don't say where you are based but, if it's UK, Maplins is worth a try & for USA, do Radio Shack still exist?  In both cases, if material is still available, I suspect it will be a close match but not identical.  With regard to affecting the value, 'how long is a piece of string?'.  In other words, it will probably depend on the buyer.  On the other hand there are some wizards on this forum who just might know where to get the exact match.
Good luck!
John
Any thing other than the original material will have a vast effect on the value. However, with a torn fret, you should not have paid a great deal for them!
Personally, I would not entertain anything other than the original so I wouldn't buy them at any price unless I wanted them for spares.
I'm sorry, I'm in the US. It seems the quest is now on. What I would like is to find material as close as possible to factory of course and I guess the only way to do that is start doing some leg work. How true on how long is a piece of string, great way to phrase that.
In regard to joeyboygolf I picked them up for $15 each. At $30 I figured I can live with the torn grill cover until I can find a suitable replacement. Thanks very much, this site is tremendous wealth of information.
Splendid advice! It hadn't occured to me to keep the original fabric. I will be certain to do so now. By the way, I had mentioned the Penta's I purchased didn't sound right earlier in another post. I took the grill covers off and all of the driver surrounds are in perfect shape. Do the controls at the bottom of the speakers have any particular order they need to be set at? Thanks again.
Bargain!!
At that price you could cover them with whatever takes your fancy. You are never going to lose money!
What model Penta are you talking about?
$30USD FOR A PAIR OF BL5000?!?!?
P.S. Welcome to BeoWorld!
I will pay double that if you wish to sell! 😜
I think mine are Penta 1's. The model is 6603. I must have not had the speaker cable plugged in all the way. I hooked them up again today and the sound much better, they still sound like crap as I have a mid driver out in each tower. They were the same price that I paid for the 5000's so I think I swing the price for a couple new mids. Once I get them running properly I think I'm going to look harder at the Penta upgrades available. I take it the Penta 1's aren't the most desirible of the lot.
