Beolab 5000 (flat panels) connection Beocenter 9300
I hace a pair of Beolab 5000 and i would like to connect them to my new beocenter 9300.
The notice shows that i can connect one panel to my beocenter (using one power link cable), and one power link cable to go from one panel to the other.
Is it ok for the stereo signal ?
Thanks for your respond
Yes. Powerlink carries let and right signal.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thanks Ralf
Make sure you buy Mk2 Powerlink cables, not Mk3.
You need the fully wired cables to enable the displays on the BeoLab 5000s.
Lawrence
Ok Lawrence Thanks
And set the switch at the speakers to left and right respectively.
Ok Dillen
