BeoLab 50 connected to roon Nucleus via USB
Thanks Flere !!
I am trying to find a way tu use the Nucleus , but with the 50's also connected to the Eclipse
Jan
You can use PowerLink cable connection between Eclipse and BL50 master.
And USB for the Nucleus.
Switching will be automatic and according to the priority you configure in the BL50 with the B&O app.
Flere,
what kind (brand/type) of USB cable have you used?
Apparently that is very important to get the best result.
thanks
Jan
Connected the Beolab 50's to a Nucleus with an audio USB cable, works perfect !!
The Eclipse is also still connected with the 50's.
Sound is amazing , very happy !!
What settings do you change to prevent the Roon for stopping when Mac goes into screensaver? After half an hour the music suddenly stops.
Hi I am trying to get my hands on a pair of 50”s. Here it means breaking up walls as I hate cables in sight. I have an open floorplan and want to run the 50”s in the living and a second pair in the kitchen synchronized. Probably a shape.
I have a Oppo 203 which I can use as a RAAT endpoint on a BS core optical and the 50”s on a nuclues, here comes the question will it run synchronized? So is there any way that multiroom will run on Roon synchronic or am I stuck on the BS Cores? I won”t cast, I hate google and airplay is not for me.
I will wire them with PL as well on a system 4 but I would like to have the option of multi room Roon. The volume is great I was looking for this as I still want easy control, but sound is more important.
